Lock the screen on A925
5 replies · 2,078 views · Started 04 March 2005
platao wrote:Can someone tell if is possible to lock the screen or the virtual keyboard on A925?
Yes, according to the manual, you should press the "shortcut key" ("bent arrow" above the power button) and after that the "Game B key" ("two dots" button on the top right of the phone). And lo and behold, it works. Sometimes reading the manual helps 😉
albatorsk wrote:Yes, according to the manual, you should press the "shortcut key" ("bent arrow" above the power button) and after that the "Game B key" ("two dots" button on the top right of the phone). And lo and behold, it works. Sometimes reading the manual helps 😉
Thanks,
Rami
albatorsk wrote:Doesn't anyone read the manual? :P
Sometimes, all depends what it is. With the A925, i had to. Actually, with the A925 you need to.
