is there any posibility to find out the lock code, and the wallet code, cose i bought a 6600 with all accessories but without a user guide. is there a legal program that does that ? pleaaaase
you can reset the wallet code yourself (look in the sticky thread "6600 Codes"
to reset the lock code you need to format the phone details on that are also in the thread 6600 codes don't forget to back up all of your data first though
i know about the wallet code, all i need is to find the phone's security code.... so please tell me if there is a way to find it. i even hard formated (green key + etc) and still didn't dissappear. for the old models ( 7110) u could use logomanager and it showed me the code, but for symbian.... i coudn't find :bawling:
well the default lock code is 12345
i dont know of any program that does what you want
was the phone new when you bought it? If so the code will be 12345 if not then have you tried contacting the person/place you bought it from???
littledude wrote:well the default lock code is 12345i dont know of any program that does what you want
i tried the default code, ofcourse it is not that one 😃 DOES ANYONE KNOWS A PROGRAM FOR SYMBIAN TO GET MY CODE?
There is no such program (what would be the point with a lock code, if there was an app to disable/reset it for anyone?). Take/send the phone to your nearest authorized Nokia service center.
N/A wrote:There is no such program (what would be the point with a lock code, if there was an app to disable/reset it for anyone?). Take/send the phone to your nearest authorized Nokia service center.
Yeah, right that N/A, there is no such a program or application, (beside some dongle protected programs..) but that�s the completely different story.
But there is an trick how to reset them to default, as always SF team has solution for almost every know problem 😃 😃 😃 😃
In conclusion:
u don�t need to look for nearest Nokia SC and pay them to fix that 😃
Cheers
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
So could u PLEEEEEEEASE tell me the "trick"??
I have a similar problem, have you solved yours. There is a software you could try but it requires a special software which i dont have. go to unlockme.co.uk for details. just click security code on the links menu.
pls replyby email i dont always check the forum.
[email][email protected][/email]
neodoru wrote:i tried the default code, ofcourse it is not that one 😃 DOES ANYONE KNOWS A PROGRAM FOR SYMBIAN TO GET MY CODE?
If the default security code doesn't work in your 2nd hand Nokia 6600, You can do a master reset to your phone. This could simply restore your phone with default factory settings. You can get the free master reset code for your Nokia 6600 from http://www.unlocking4free.com/nokia-master-reset-tool by submitting your mobile model and IMEI number.
actually you can get unlock code from your telco, so call them to get the default unlock code.
I didn't know anybody was actively working on a massbus emulator.
