3:rd party calendar?
1 replies · 1,508 views · Started 05 March 2005
Ciao!
I can't get the calender on my 6670 to work properly, it doesn't sync if there's two overlapping events.
Is there any other calendar for symbian that you guys would recommend?
/Ess
Hmm that sounds like a PC Suite issue - are you using the most recent version (check the nokia.com site).
There aren't any direct replacements. I think they all tie into the inbuilt Calendar engine (to allow for syncing) - you might want to look at Aqua Calendar though.
