I just want to detect an outgoing call disconnect it then make a new call,
but when the run reaches to Dial method the iStatus of my RunL encounter with an error, -9 (KErrOverFlow),
what does it mean,
I am running the code on Nokia 6600,
The RunL code:
if (iStatus == KErrNone)
if (iCallStatus == RCall::EStatusHangingUp || iCallStatus == RCall::EStatusIdle || iCallStatus == RCall::EStatusUnknown)
iCall.Close();
if(iFlag )
TBuf <100> newCallName;
iCall.OpenNewCall(iLine, newCallName);
iCall.Dial(_L("03656655"😉);
else if(iCallStatus == RCall::EStatusDialling)
if(iFlag )
iFlag = false;
else
iFlag = true;
RLine::TLineInfo lineInfo;
iLine.GetInfo(lineInfo);
iCall.OpenExistingCall(iLine, lineInfo.iNameOfLastCallAdded);
iCall.HangUp();
iLine.NotifyStatusChange(iStatus, iCallStatus);
SetActive();
else
WriteToFile(iStatus.Int());
Is there any Idea? this code works correctly on nokia3650 and SEP900,...
If the red line be in comment, the code works correctly, but when it calls here the -9 occured in iStatus,,,
and also the Dial method itself returns 0 which means KErrNone... !!!
(the version of this 6600 is: V 5.27.0)
