6620,how can i browse the system folder on a PC
7 replies · 3,195 views · Started 06 March 2005
i cant find any programs that allow you to browse the files of the "system" folders on drive c: and e😞memcard). pc suite doesnt let you. file manager doesnt even recognize the phone. i can browse it via fexplorer, but i need to be able to browse the "system folder" from XP.
To have access from your phone to all the drives c: d: e: z: use SeleQ.
to have access from a PC (infrared -bluetooth) use Total Commander with the Symbian plug-in.
edjecadetje wrote:To have access from your phone to all the drives c: d: e: z: use SeleQ.
i got total commander and the plugin. followed instructions, installed runtime and all, added plugin. in total commander when i go to the "symbian device" under network neighborhood, i see no phone drive directories when i click on it. im i missing something? is this compatible with the 6620? cant get it to list my directories.
the plugin has either been successfully tested by the author or the author has received reports of it working for the following devices:
- Nokia 6600 (IR)
- Nokia 3650 (Bluetooth)
- Nokia N-Gage QD (Bluetooth)
- Siemens SX1 (USB)
- Sony Ericsson P900
In theory the plugin should be work for any Symbian based device regardless of the desktop connection type (USB, Bluetooth, IR, ...)
I think it's not compatible with 6620.
In order for the plugin to work both mRouter and the Symbian Connect QI API runtime must be installed. mRouter is usually installed by the software that ships with the phone. So make sure you have the PC/device connectivity software installed.
Symbian Connect QI API can be downloaded separately ( http://www.totalcmd.net/files/SCRuntimeSetup22.rar )
SUCCES
bump. 6620 is not compatible. anyone out there with a 6620 nokia able to access there "system folders" on nokia c: and E: drive from there PC? I cant find any solutions.
medafor wrote:bump. 6620 is not compatible. anyone out there with a 6620 nokia able to access there "system folders" on nokia c: and E: drive from there PC? I cant find any solutions.
Havnt found any way to do that...and if that program you were using needs mrouter, thats why it wont work as the 6620 dosnt use mrouter to connect.
theres no way to do it. every single piece of software made to do this uses mrouter which has been killed in the latest pc suite software. 😞
