help with tomtom mobile for nokia 6630
3 replies · 1,262 views · Started 06 March 2005
hi, have got tomtom mobile on 6630, anybody else got it and is the speed camera software poi working ok? cant get my speed camera poi to show in poi settings !! any help please..
Hey,
You have downloaded them & copied them to the correct folder?
They are not part of the standard TomTom installation & need installing seperatly.
Ian
yes have downloaded sped files uk gatso and copied them to great britain folder with still no joy!!! can you help me, have you got it running all ok then on 6630 and what size is your dv rs mmc card ?
Hey,
I haven't tried them on my 6630 as yet as I am waiting for the new TomTom 5 to be released which is to one I shall buy. But I was using them ok on my 6600.
Ok, so you've downloaded them & unzipped the file to your PC.
You've then transfered the correct .OV2 file & matching .BMP file to the GB Map on your rs mmc.
Have you then through the POI manager in TomTom selected the POI's to work? Literally turned them on or set them to on in the program itself?
Just an idea but they won't just come on automatically once copied to the right place, you need to select what POI's work in TomTom.
Ian
