Hello erveryone! Can anybody help-me. I had formatt my mobile phone Nokia 6600 by pressing this code *#7370# i restart my mobile, the games are not there in the apps manager but the icons of the JAR games it still showing in the Menu, so how can I delete it? Thanks :icon14: KIDROCK
Nokia 6600
Do a hard format instead...
*#7370# is only soft format...
Hard Format
Press and hold 3 keys: [Green dial key]+[*Star key]+[no. 3 key]
dunbother wrote:Do a hard format instead...
*#7370# is only soft format...Hard Format
Hi, dunbother. Thank You for yr reply. Today i went to a Nokia Store and they upgrade my software to a V 5.27. And the icons still there. So if a make a hard formatt , i will have a software 3.42 of origin or this one that i have now 5.27. Can u help me? Thank you
KIDROCK :icon14:
Note: Formatting the phone has no impact on applications installed on a memory card (MMC).
N/A wrote:Note: Formatting the phone has no impact on applications installed on a memory card (MMC).
The question is if i make this hard formatt will a loose the upgrade made by the Nokia store to my memory phone, because i had a software 3.42 and now a have 5.27. Can i formatt it without loose the upgrade?
KIDROCK :icon14:
The upgrade is made to the software in ROM; in other words, that's where the 5.27 sits and the formatting does not impact it.
N/A wrote:The upgrade is made to the software in ROM; in other words, that's where the 5.27 sits and the formatting does not impact it.
Thanks, do i have to remove my sim card to do the hard formatt?
:icon14: KIDROCK
KIDROCK wrote:Thanks, do i have to remove my sim card to do the hard formatt?
:icon14: KIDROCK
no, you can leave it in there. it wont do it any harm
dansansome wrote:no, you can leave it in there. it wont do it any harm
Ok, thanks. I did the hard formatt, and the soft format but the icons of the game still there in the Menu, how can i remove it or delete it. Plse somebody help me. Thanks
KIDROCK :icon14:
you could try re-installing the games and then uninstalling them again (im assuming these games were installed to the mmc card?)
or use seleq/fexplorer to browse through e:\system\apps\ and delete the folders that relate to the deleted games. (i think within those folders the *.aif file is the game icon)
Hi everyone. I want to thanks to everyone who help to solve this matter, finaly a delete it and remove the icons of JAR games. Thanks. KIDROCK :icon14:
