Bookmarks 9500
3 replies · 2,407 views · Started 07 March 2005
Forgive me if this is obvious, how do i get bookmarks from IE to Nokia 9500 tried nokia pc suite no options in there, and also tried looking for the file on the 9500 but could not find the default bookmarks file.
Any ideas(p.s. I am a newbie to these kind of things)
I am not sure if it works but in my opinion it should because it is the same way as i copy bookmarks from 9500 to 9300:
First connect your 9500 with the PC via Infrared Ports
In the Internet-Explorer
Right klick to the desired bookmark
Then chosse send to
then choose "Infrared connected Computer, i.E. 9500
That should be your bookmarks via InfRed to your 9500.
Bye
Klaus
Tried it, but seems to sent it as a file, tried to save it, it then askes where to save it, tried saving to default area, then checked the 9500 browser and they are not in there,
is there a file i can replace on the 9500 with my favourites is some kind of format?? thanks for reply though.
It could be me being a donut?!?!?!?!
I think it needs some kinda tool in between. IE uses "shorcut files" (in lack of better namefor them) while I understood that in the 9500 they are in a DAT file??
