can you add internet explorer on nokia 6630
5 replies · 21,007 views · Started 07 March 2005
Hi, can anybody help !! im trying to view internet and not wap on the nokia 6630, is there a internet explorer to download for the phone? or how do i look for internet pages, ie google, ebay etc.hope somebody can run through the settings with me..
dunbother wrote:6630 is html recongize
hence dun really need a 3rd party software to surf web....
You need to install Opera, that should be either on the Memory card that came with the phone, or on a CD that came with the phone.
Then you can access the real web (if you have the phone set up with a proper internet acces point).
As stated, the built-in browser can be used to access web/HTML sites (it supports both WAP 2.0/XHTML and HTML 3.2/4.0). Best used with a GPRS Internet Access Point (a WAP Access Point will do, too, if your operator allows access to all Internet sites through their WAP gateway, and don't do automatic formatting/transcoding of web pages).
