sendo keyboard help!
1 replies · 1,644 views · Started 07 March 2005
im considering buying the sendo x keyboard but jst wanted to know if anyone knows/thinks it can be used with other phones or newer phones in the future possibly!?
thanx!
First off, it's absolutely a great keyboard!
However, it probably won't be able to be used with any othe phones, unless they use the same connector as the Sendo X does. Unfortunately, it won't be compatible with the X2, as that uses a mini-USB connection.
There might be some converters of some type made available at some stage.
