I recently had my Nokia 6600 unlocked so I could use my old Vodafone Sim, but as the phone was originally on Orange PAYG it still has all the Orange software installed and I cant use Vodafone Live 😞
Is their any way I can remove the Orange software and reflash the phone with Vodafone software?
Thanks in advance,
Daz
Hopefully you've got the problem sorted by now, but all you need to do is get your network provider (Vodafone/Singlepoint) to send you the MMS & GPRS settings. They can do it via your message inbox, then you just save the settings from there.
Some of the Orange stuff may be in Read-Only Memory (ROM). If so, they cannot be removed without having a service center flash the phone with a firmware package without Orange stuff in it.
