hi new to this ,i am looking at buying a nokia 6670 or 7610
can any body give me advise on what software to use for sat nav and what bluetooth gps unit i would need
thanks keith5363
sat nav for6670/7610
N/A wrote:http://www.wayfinder.com/
http://www.tomtom.com/
http://www.66.com/route66/index.php
http://www.navicore.fi/en_GB/frontpage/
thanks for that.
keith5363
Would these applications work in australia?
The apps will work, but the question is: Do they have maps for Australia?
At this point of time, they probably don't, but check with them; I'm sure their web site or their support/info email addresses can help in answering the question.
Yeah i check and they dont.
Thanks for that.
I would like to buy a gps receiver for around 60 - 70 quid for ma 7610, seen some altino ones or something on ebay for 50 quid, any ideas will be nice please thanks
tom tom does have maps for australia now,i have it but i have no idea how to install it onto my 6670,any ideas how to install it anyone?
just put the map folder onto the route of the memory card by using a card reader or that. Then open tomtom go to change preferences and in the 4th menu select switch map.
i cant install tomtom on my phone thats the prob......
