Hi
Resently downloaded FExplorer 1.12 & install on my N-Gage QD, application installed properly but I cant fine shortcut to it, but then using FileMan I am able to start FExplorer from C:\System\Apps\FExplorer\FExplorer.app & its working perfectly fine. Please tell me how can i create shortcut for this. I even tried reinstalling it but got negative result.
Thanks for help
Rustum
Does version 1.11 install and work OK? If it does, use it, instead.
And for problems with a version and/or a particular phone model, there is a "Contact" link on the FExplorer site http://www.gosymbian.com/ that you can use to contact the developer directly.
Thanks for the quick help, but i already tried 1.11 version & got same results its not comming on desktop (of my mobile).
Rustum
rfvirani wrote:Hi
Resently downloaded FExplorer 1.12 & install on my N-Gage QD, application installed properly but I cant fine shortcut to it, but then using FileMan I am able to start FExplorer from C:\System\Apps\FExplorer\FExplorer.app & its working perfectly fine. Please tell me how can i create shortcut for this. I even tried reinstalling it but got negative result.Thanks for help
Rustum
Hm,
I really need more details�
Did u has aif file in fexplorer dir (from C:\System\Apps\FExplorer\) !?
For now u can put them in go to menu, it will helps u until we find out what�s wrong with fexplorer
IF u don�t know how chk below link:
How to put clock shortcut in "Go to" (ask guru form)
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
Thanks a lot this solved my problem.
Regards
Rustum
rfvirani wrote:Thanks a lot this solved my problem.Regards
Rustum
N P, anytime 😃
Glad to hear that 😉
Regards
