How can I delete the reports of the sms? I know it isn't a very important question but in the others nokia phones we can do it....
Be cool
Be cool
[quote="levi"]How can I delete the reports of the sms? I know it isn't a very important question but in the others nokia phones we can do it....
Be cool[/quote]
You may do it by going to Menu -> Log. Surf around there then you'll find yourself in a list of logs, just press option -> clear logs.
That will do. 😊
If you mean the delivery reports, AFAIK there is no way of deleting those reports - you just have to turn delivery reports OFF and until nokia fix this there is no way of deleting those reports.
[quote="phunkyphonez"]If you mean the delivery reports, AFAIK there is no way of deleting those reports - you just have to turn delivery reports OFF and until nokia fix this there is no way of deleting those reports.[/quote]
Correction, up till what i know for now. There's only one way of clearing the reports.
Goto Menu -> Log. Then push your joystick to right side, you'll then be brought to the other list of logs, that will be your sms report logs.
When you're at there, select Option -> Clear log. That will do. It'll clear your delivery reports.
Hope that helps. 😉
