Does Logomanager support the 7650
4 replies · 2,115 views · Started 27 October 2002
Does Logomanager support the 7650 ? If so does it need to be setup differently to the 7110 when using an IRDA connection
Thx
Logomanager does not support the 7650! I advise you to search through the forum about this topic! it ahs been asked again and you could find some more info!
Logomanager does not support the 7650.
Its not really useful for the 7650 if it did suppord it.
Anything you need can be done with IR or Bluetooth straight to the phone.
