Does anybody know the settings for Fido GPRS on the nokia 6260? My Fido MMS works fine?
6260 Fido GPRS settings
Hey dalenag here are the settings...
Create a new connection and put any name you want:
Data Bearer = GPRS
Access Point Name = internet.fido.ca
User name = none
Prompt password = no
Password = none
Authentication = normal
Homepage = http://wap.fido.ca
Advanced Settings:
Phone IP = Auto
Primary name server = 0.0.0.0
Second name server = -0.0.0.0
Proxy serv. address = 205.151.11.11
Proxy prot number = 8080
That's it! just make that your default web connection.
It works with mine! 😊 Cheers!
you can generally get your network settings from the nokia site
krycek,
those settings work awesome.
thank you very much
ur welcome eh 😃
hi there, i'm just wondering if you would also know the correct Fido MMS settings. i can get the GPRS to work, but i've tried so many different ways and couldn't get the MMS to work 😞
many thanks !!!
Here u go...
Connection name = <any name>
Data Bearer = GPRS
Access Point Name = mms.fido.ca
User name = none
Password = none
Homepage = http://mms.fido.ca
Advanced Settings:
Phone IP address = Auto
Proxy serv. address = 205.151.11.13
Hope that helps!
Big thanks to Kryck for that post about the MMS settings. Now I have a problem sending MMS to anybody other than fido. I hate fido. Does anybody know if they support sending MMS to other networks other than fido? a reply will be really appreciated. Thank you guys
I have no problem sending mms to other networks (fido/rogers, telus, bell .. even abroad). The limit is 300k for Fido, so if your message is larger than that it won't work. Hope that clarifies things.
im using fido and i can only send mms to fido users..can u help me please?? thank you
yes i am using fido.
