Creating/Adding custom MTM
0 replies · 1,974 views · Started 09 March 2005
In general camera application for series 60 device there are options for sending the image via multimedia,
bluetooth or infrared. My question is,
Is it possible to send the image file to another application on the device which then handles the actual
sending of the image?
Is it possible to modify the command options "Send-As" for a built-in application like camera ?
and add a command such as "send via TestApp".
How do MTM's come in the picture.
Kindly suggest if sample MTM's are written.
Thanks.
shashi.
