Connectivity SDK for the 9210
2 replies · 1,857 views · Started 24 December 2001
I need to move (copy + delete) a specified folder on the 9210 to the PC. I was informed that the Connectivity SDK is needed for this, but it is not yet available with 9210 support.
Any suggestions? Does anyone know when this SDK will be available?
Thanks.
Actually it's been out for a while, but I don't think you need it for this. You need PC Suite for Communicator that came with the 9210. Just drag the directory from 9210 to Explorer on the PC and when you're happy that it has all worked then delete the original. BUT please check the files are in the format you expect, i.e. you can read them !!! I have had lots of trouble with it converting some files and not others User posted image(
If you DO want the SDK you need to register for it, go to http//www.forum.nokia.com/main/1,6668,1_55,00.html and have a look at what the SDK does. If you still want it, go to http//www.forum.nokia.com/reg_form/1,14554,,00.html to register and follow the instructions.
Thanks for the response, bu t section 1.2 of the manual for the SDK lists the phones supported and the 9210 is not one of them. It was Symbian that clued me in initially that the 9210 SDK was in the works.
Unfortunately, the drag and drop from the explorer is exactly what we do not want the user to do. Do you know of any other way of doing the file moves programmatically without the SDK, direct API calls perhaps?
Thanks.
