I'm having trouble connecting my 7650 to my pc, which has the above O/S...
Does anyone else have this trouble? And is there a way around it
I'm using the MA 620 infrared adaptor...
Sync'ing my phone book doesnt work although sometimes the phone connects ok i just cant sync or back up my phone.
As you are probably aware ( it warns you when you install ) Windows XP is an unsupported O/S, I am using the exact same setup as you, and do get errors, but nine times out of ten it works, there are loads of responses if you search this forum, if you have sp1 installed then uninstalling it can help..otherwise you will have to wait til Nokia produces updated software....don't hold ya breath!
