9500 pda pops open very easily
6 replies · 2,689 views · Started 11 March 2005
Hi all,
Does your 9500 pda side opens when you hold the phone up-side down (phone side to the table for example)?
The hitch opens very easily, this bothers me a bit, therefore I want to ask other 9500 owners if they have the same...
Thanks in advance,
Jan-Willem
comfirm.be
Only if I hold it upside down and give it a good shake !
Not that I tend to use my commi in this position very often :tongue:
Read of similar cases on 9500communicator.com forums, fortunately this has not been the case with my 9500. Mine is "Made in Findland", is yours "Made by Nokia"?
I suspect the build quality of "Made by Nokia" 9500s may be a bit lacking. There is a solution to this latch problem, but that involves opening up the 9500 (removing the PDA keyboard).
yzaholdings wrote:Read of similar cases on 9500communicator.com forums, fortunately this has not been the case with my 9500. Mine is "Made in Findland", is yours "Made by Nokia"?
Could you specify more what this solution involves?
