Media Files for the Nokia 7710
10 replies · 7,931 views · Started 11 March 2005
I have a Nokia 7710 and tried to play media Files with it.
if I make a movie with the included camera it is no pb to replay that movie.
On my PC harddisc I only have wmv files. so I chhose a wmv file choose open with and choose my realplayer (cuz the nokia only has a realplayer).
then I transfered the realplayer file on my nikia...but I get the message "unknown format". 😮
well my question is:
can anybody say how I can convert my wmv/mpg/mpeg files into nokia 7710 realplayer compatible files?
or is there anywehere a windows media player that will run on this system?
Thanks in advance,
cheers Rumbalotter
First thanks,
I tried,
but the first video file couldn't be converted.
With an another the convert works. Then I put the "myvideo.avi"
onto my phone, and tried to play it
1. with the realplayer --> unknown format
2. with the mobile media player - search - nothing found but I had to remove the batterie, to make the phone working again
so not the right way for my phone?
How did you make it with this software, can you please explain it to me more detailed
EDITED:
First thanks,
I tried,
2. with the mobile media player - only many colours on the display but no images
I'll have to admit, I get the same results (many colours, no image). But I thought it was because of the file I was using or something. Apparantly the software is not as good as it claims to be :frown:
mmmmh 🙄
maybe another user knows a solution?!?
I'd like to know what nokia is thinking which kinds of movies are running on the phone. I don't think that everybody has a lot .3pg Files on his disc 😉
