Ok, I'm currently still stuck with the 16Mb memory card that came with my 3660, but I'm thinking of getting a bigger one. What is the maximum capacity sopported by the 3660? And is there any way of transferring all data on the current card to a new one?
Memory card
Any size MMC (make sure to get an MMC, MultiMedia Card rather than SD, Secure Digital card) should work in principle, but your mileage may vary.
The best way to transfer all data on the current card to a new one is by using a PC-based card reader (copy all files from the card to the PC and then from the PC to the new card).
Im using 128mb of memory card, and i heard 256 is also supported by 3660 but check first your firmware if it is the latest one.
i recently purchased a 64mb memory card. i've been transferring date from my 16mb card to my phone memory then to the new 64mb manually. Coz i don't have a card reader.
I downloaded applications like Fexplorer,photographer and some ringing tones which are saved in my 16mb and i can't seem to transfer them to my phone memory.
Is there a way to transfer them or the card reader is my only hope?
You can transfer the files one by one to phone memory and then back, but a card reader would be the easiest way.
N/A wrote:You can transfer the files one by one to phone memory and then back, but a card reader would be the easiest way.
Can you teach me how? Because i can't see any option to transfer the Fexplorer to the phone memory? Looks like its stuck in the memory card :frown:
If you want FExplorer in phone memory, reinstall it.
i guess there's no way to do it manually then.
Oh, the other download i have is ringtone studio...is there a way to transfer to memory card?
my messages transfered to memory card automatically.is that anyway to move it back to device memory.I'm used n-gage qd 😊
