Hi all,
Just bought the phone here in the uk a day back
Tried to update the my P910i firmware.. went to the site entered the CDA �CDA162006/5�.. clicked thru the options provided did what was necessary, and it all started well.. all is going well so I thought but it was not meant to be 
Second stage was up to 48% and it just got stuck there� waited for a few min nothing happened � a dialog popped up saying its not able to connect and asking me to check the bateryies and replace the cover and put it back in the station .. did that ..
But it just didn�t happen it stopped updating and said unable to connect to the device and stoped ..
Started it all over again .. again .. again .. and again .. un-install the whole update service app and did it again still no luck � decided to investigate and had a browse thru the java console and the application log that it generated
Here is the error part and the full log file attached
08.57.26:609 302 Result All ok (by) homeflash.msconnector.fb
09.05.51:187 327 Exception Ouch java.lang.Exception: Failed to get header byte!!!
at homeflash.msconnector.b.e(Unknown Source)
at homeflash.msconnector.b.b(Unknown Source)
at homeflash.msconnector.b.a(Unknown Source)
at homeflash.msconnector.l.a(Unknown Source)
at homeflash.msconnector.ic.b(Unknown Source)
at homeflash.msconnector.ib.c(Unknown Source)
at homeflash.msconnector.jb.a(Unknown Source)
at homeflash.gc.e(Unknown Source)
at homeflash.re.c(Unknown Source)
at homeflash.re.run(Unknown Source)
(by) homeflash.msconnector.b
09.05.51:265 330 Info ###### Script stopped, HL1_pg_P910iCDA162006/5OrangeUK_f_041207_1200_2
(by) homeflash.msconnector.ic
scratching my head now 
would sincerely appreciate your help
cheers,
Parthi
