Formatting Nokia 9210 Device
1 replies · 7,828 views · Started 25 December 2001
I try to format my nokia 9210 device, I took off the battery and then put it back and then I pressed Ctrl+Shift+F it gives me the "Are you sure you want to format....." when I press format nothing happens at all and then I go back to the welcome screen and everything is there, I tried to format it using the data suite by formatting the C drive but I got an error that says something like "file is locked or in use" I went to nokia but they told me that I have to leave my device for 4 days just to do the format,
So is there anyone who could help me to do a format without having to go to those nokia's people.<font size=-1>[ This Message was edited by seiftawfik on 2001-12-25 1939 ]</font>
Hi!
I�m not sure, but you could try to delete all your *.ini files before formatting.
Anyway, wait for more posts.
Regards
