Hi i am trying to build application for series 80
I am able to build this for UDEB but when i try to build it for UREL(For Target) it gives the following error
It will be helpful if someone have the solution for this?
Thanks in advance
C:\Symbian\7.0s\S80_DP2_0_SDK\examples\helloworld>abld build armi urel
make -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\EXPORT.make" EXPO
RT VERBOSE=-s
Nothing to do
make -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\ARMI.make" MAKEFI
LE VERBOSE=-s
perl -S makmake.pl -D \SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\HELLOWORLD ARMI
make -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\ARMI.make" LIBRAR
Y VERBOSE=-s
make -s -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\HELLOWORLD\ARMI\
HELLOWORLD.ARMI" LIBRARY
make -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\ARMI.make" RESOUR
CE CFG=UREL VERBOSE=-s
HELLOWORLD.ARMI" RESOURCEUREL
make -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\ARMI.make" TARGET
CFG=UREL VERBOSE=-s
[COLOR=Red]HELLOWORLD.ARMI" UREL
make[1]: *** No rule to make target `\SYMBIAN\7.0S\S80_DP2_0_SDK\EPOC32\INCLUDE\E32BASE.H \SYMBIAN\7.0S\S80_DP2_0_SDK\EP
OC32\INCLUDE\E32BASE.INL', needed by `..\..\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\HELLOWORLD\ARMI\
UREL\HELLOWORLD_APPLICATION.o'. Stop.[/COLOR]make: *** [TARGETHELLOWORLD] Error 2
make -r -f "\Symbian\7.0s\S80_DP2_0_SDK\EPOC32\BUILD\SYMBIAN\7.0S\S80_DP2_0_SDK\EXAMPLES\HELLOWORLD\ARMI.make" FINAL
CFG=UREL VERBOSE=-s
