mobiclip converter
0 replies · 2,766 views · Started 14 March 2005
i downloaded mobiclip (home edition if it matters), and i looked at what files where compatible,(.MO) so that i could convert some clips into the format. the only problem is i have no clue what converter to use. i didn't understand anything that it was telling me to look for.
:con?
"You can create contents using standard authoring tools like Adobe Premiere or Macromedia Flash and then convert them into the Mobiclip format(.MO) with Mobiclip Home Edition."
:con?
but when i look for adobe premiere or macromedia flash it wants you to buy the softwear. is that the only chice or is there another way to do this?
someon please help me.
