Hi All,
1. I keep on getting the message "MMS waiting. Close Connections to receive message?" When I select "no" it simply comes back a few minutes later. If I select "yes" then i get a double arrow? sign under the 3G reception bar but nothing happens. Sometimes it resets itself.
This might be from some *ahem* free applications I put ontu it, with this in mind is there a hard reset for the 6630 that will reset to factory settings?
2. Also I transferred an MP3 file via BT about 15seconds long ontu the MMC, and it worked fine as my ringtone for a day, but now it's just defaulted back to that horrible Nokia theme tune. I remember my old 6600 did something like this too, any idea's?
3. Finallly I had a Futurama Theme for my old 6600 I loved but the clock is a little bit "off" now it's on the 6630, again, any idea's on how to fix this?
Thanks for any help in advance 😊
Rob
