digital certificates
3 replies · 3,022 views · Started 15 March 2005
Hi:
I have a small problem.. All my n9500 is OK and I am happy with this phone.. but I am trying to install a Digital Cert (thawte for example) but in Control Panel -> Security -> Cert manager, select ADD, select my digital cert... it ask my digital cert parrword and all is OK..
But it shows my cert and in the final ADD the phone ask:
KEY STORE PASSWORD
Enter the current key store password:
What password???? It is NEW... (a few days ago) and in nokia support (at least in Spain they know nothing...
Did somebody install it? Does somebody know the password?? (1234 doesn't work 😞
Thank you
Hi, and welcome to AAS.
Hmm, why are you trying to install a digital certificate, and where did you get it from? What is its purpose?
OK. It is easy...
- Access to some web sites who need digital cert to identfy you (for example my company internet (e-pyme.miescritorio.net)) or some Spain official web pages where I can pay for example my tax...
- Sending digitaly sign emails...
-Encrypt decrypt information with my public key, etc...
You can read about this in www.thawte.com for example...
I need it in my mobilet for testing our company web scripts who use digital cert for our cliente security.
Ciao.
Guss:
I have the same problem. Did you manage to solve it? I don't know the
key store password of my brand new 9550 and in addition I'm trying to
add a "Other" certificate to trust our Certification Authority and I get
a message that says that the operation is not supported.
Any clues?
