An application to set / delay the backlight going off would be a such a blessing. I have "Torch" installed but I'm looking for something that can keep the light on when running other applications/games. Any suggestions apart from using joystick /keypad ever so often?
[quote="sanjay2402"]An application to set / delay the backlight going off would be a such a blessing. I have "Torch" installed but I'm looking for something that can keep the light on when running other applications/games. Any suggestions apart from using joystick /keypad ever so often?
Thanks[/quote]
"Torch" could do the job. Just let it run in the background while you load your other programs. 😉
Thanks so much i2umi. Why did'nt i think of it :roll: Now i'm Convinced i'm a Dumbo!! 😃
Thanks again!
[quote="sanjay2402"]Thanks so much i2umi. Why did'nt i think of it :roll: Now i'm Convinced i'm a Dumbo!! 😃
Thanks again![/quote]
Hehe. Sure. No problem. You're welcome. 8) 😉
Ehh...what is the "Torch" ? 😮ops:
Torch is a small li'l application that leaves the Backlight on..until u close the application. Handy in dark. You can find the file posted in this forum. Search for "Torch"
