help me 7610 problem!
3 replies · 1,863 views · Started 17 March 2005
hey! the other night i put some songs in2 my 7610 as usual, and didn try and listen to them until the nxt mornin ... i attempted openin thru realplayer ... "memory card clips" ... but no luk , so i tried thru the gallery, but only to find wen i go in2 the memory card bit and clik sound clips ... then all tht happens is the memory card bit opens up agen wit the images bit highlighted! so ,... iv tried loadsa things ... restartin the fone . chekin the mem card . original phone settings ... formattin the mem card ( which btw doesn even work!!! ) . and wot els ... oh yeh in the EXTRAS bit and file manager thing it scans the mem card memory and says tht the messages ate 1147Mb ... now wot is up wit tht!!!
Also i hav Fexplorer and it just closes wen i try accessing the E:soundclips thing ... and also same goes for tryin 2 access it and delete the songs outa the sound clips folder thru the data cable and pc suite! on the fone an error comes up sayin sumthin bout SRCS error!!!
PLZPLZPLZ sum1 help! asap!
CHEERS! 😮
Not even halfway trough your post I couldn't stand reading anymore. So I don't know if I could have helped you or not.
Lewp wrote:Not even halfway trough your post I couldn't stand reading anymore. So I don't know if I could have helped you or not.
so wots the point in replyin ... 😮 .... i kno now wot it is anyways ( mem card! ) ... cheers for the help ! hint ... sarcasm!
cya! 😡
hey man from where did you buy your memory card ?
is it the original memory card ?
if (no) how many dadys did you use it for ?
so if it is the original memory please go to the nokia retailers in oxfordstreet and tell them the problem and if ther is a big prob they will change the memory for you for free .
