My 6630 screen don't fit correctly in the window (the image is not straight).
Anyone with this problem?.I have the last firmware.
6630 screen problem
That's a common software bug.
To fix it, press "green", "3", "9", "#", "*", "s", "o", "d", and that little speakerphone key on the side, and short-circuit pins 2, 4, 7 and 82 of the multi-flange port whilst holding the phone inside a 2 litre tub of marmite. This will do the trick.
Or alternatively you could try taking it back to where you bought it for an exchange 😉
fannypad wrote:That's a common software bug.To fix it, press "green", "3", "9", "#", "*", "s", "o", "d", and that little speakerphone key on the side, and short-circuit pins 2, 4, 7 and 82 of the multi-flange port whilst holding the phone inside a 2 litre tub of marmite. This will do the trick.
Thanks but as is in garanty is easy to get perhaps a new one.
