New pc suite no longer works
1 replies · 2,167 views · Started 18 March 2005
I downloaded the latest Nokia PC Suite, as I heard it is a lot better than the old version I have. But now when I try to make the phone and the pc communicate via Bluetooth, it doesnt seem to work.
Does the N-Gage work with the latest PC Suite? I looked on the website for compatibility lists and the N-Gage wasn't listed. Ive paired up the phone succesfully using the latest Suite, but when I select Content Copier and then the first ratio box, and then 'Select a phone', the phone is displayed, but grayed out and I cannot select it.
Any ideas you could share with me and I would be most grateful 😃 😃 😃 😃 .
The only PC Suite that works with the N-Gage is the one one http://www.n-gage.com/ (version 5.x -something specifically for the N-Gage).
The version 6.* PC Suite versions don't work with that phone.
