Sending attachments via 7650
1 replies · 1,702 views · Started 29 October 2002
Hi
Firstly I would like to say thanks to all you guys who make this forum so useful.
My question is this.... have POP3 email set up and it works fine. I needed to send an exe file via email and didn't have a normal internet connection available so via Infrared sent the file form my laptop to my 7650 in the hope that i could then send it via email as i do images and sound clips.
I couldn't get this to work bencause I could only find the option to send the file I received by bluetooth or infrared. not email.
Basically can you send non image or sound files via the 7650???
Any help?
thanks
U can use this program that will forward you file via BT, IR or Email!
Its called forward and you have to register in order to see the attachement that follows! 😊
