is posible to improve the cam quality on my 7610 with an app?
which is the best?
can i do the same on my x700 ?
which app should i use? :icon13: :icon14:
7610 camera
As far as I know, the quality is already at its best. It's still a mobile phone you know.
But you can alter the output with Adobe Photoshop (www.adobe.com) or JASC Paintshop PRO (www.jasc.com) to your likings. This is difficult, but reading tutorials on it helps. It's basically the same stuff I do with scans; brush here, brush there... alter colours a bit etc.
Well did you know digital camera's are mostly based on software?
That usually the consumer ccd/cmos chips for camera's, usually dont see the exact color that its supposed to. When the photosites on the chip are hit by light, they produce current, which is translated by software to what the image is supposed to be. And if the photosites are too close together the current can hit other photosites, which would light up certain areas in the final image when there really isnt light in that area. Thus we get NOISE in the final image!
So what im trying to say, the quality of the image has to do with the quality of the lens and the chip of the camera.... AS WELL as the software. Which is why you might see slight improvements over updating ur firmware! 😊
