Hi
As far as i can learn from other posts i come to know that i can use RSMMC card with a suitable adapter on nokia 6600.But i want to know what is the basic difference between these two cards.Is there will be any problem if i use RSMMC on my nokia 6600 as it will be future compatible.
Thanks in advance
RSMMC = Reduced Size MMC
MMC = MMC (duh)
So with the "un-reduce-size-adapter", it works fine with any normal MMC compatible device (e.g. cardreaders). But MMC was -afaik- both faster, cheaper and bigger (didn't see any 1GB RSMMC cards yet 😞)
their difference are only in their sizes...
Add an adapter to RS-MMC, a MMC and a RS-MMC (with adapter) are the same.
Current capacity as of now is 512 MB max for RS-MMC, and 2 GB max for MMC...
So if your peripheral uses MMC, it will also take RS-MMC with adapter attached...
www.computer-memory-store.com/512mb-samsung-rs-mmc.html
