[7650] What software do you want ?
9 replies · 2,942 views · Started 29 October 2002
This thread included a poll: Which do you think should be developed next ?
As you know I am developing FileOp (ongoing). In the meantime I have released KeyLock (I dont think there is much more to do to it).. Above are some ideas that I plan to implement, your votes will decide which one I take up on priority 😊.. More ideas are welcome too...
Vote up.. This is viewers choice.
Cheers
As I fellow 7650 developer 😊 I prefer options that are not already made by other developers! 3 out of 4 already exist! I voted for the Today application because I find it usefull and this does not exists for the 7650! I would make it myself but I havent finished (but are nearly there) my own app! However, tell me what you are going to do so that we dont end doing the same thing! 😃
Yeah Muffy,
The reason I included clock and safe are because they are available at a cost, (I sort of need the Safe but I dont want to buy Handy Safe 😉 )...
The today screen has been in demand and the CTRL-ALT-DEL .. just for fun (I was reading through the task API 😉 )
Yes, definitely before I start I will let everybody know.. I am sort of leaning towards Safe Myself... But lets see.. I will decide in a days time.. I hope to release the next ver of FileOp before then..
Cheers
I would like a good clock on the phone that can use other sounds for different alarms. (and skinning would be nice option 😊 )
today screen would be nice too. (with skinning 😃 )
that KeyLock program is great, thanks for it!
Task manager would be cool ... as would today screen
to talk2sk :-
This is probably really cheeky but... would you consider sharing some of the source code for the apps you have written? - it would probably provide some really useful pointers for us newbies!
Ahem!...
When you hold down the menu key, a pop-up window appears showing all running applications. By moving the joystick up/down you can switch to the selected application - something like the Alt-Tab key combination in MS-Windows (I think you knew that already 😉 ).
Now, instead of pressing the "Select" button or pressing the joystick to switch to the selected app, you can press the "C" key, and the selected app will be terminated (like the "End Task" on Win2k).
Soooo, we don't need so much a separate Alt-Ctrl-Del app 😉
(I hope nobody knew this trick! 😉 )
Ah yes, that is a simple task bar 😊..
What I was thinking was more in terms of list of processes/threads/priorities and usage details... etc..
But the usefulness 😊 maybe for a developer like me 😉
[quote="talk2sk"]Ah yes, that is a simple task bar 😊..
But the usefulness 😊 maybe for a developer like me 😉[/quote]
In case you don't have it:
Here's a small app for 7650 that is a complete task manager with hidden stuff (processes, etc). You can download the SIS file or the source code from http://www.ki-ag.de/html/tech/nokiaswitcher.html.
Cheers! 😉
I'm looking for a program for the Nokia 3650 for searching for text string within Contact but also the contact notes should be searched for this string??
