Transfered files to my fren's mmc using my ngage
0 replies · 2,921 views · Started 21 March 2005
Last night i transfered files to my fren's mmc using my ngage, after i was done i inserted my mmc back in and it was jammed on the main screen, i couldnt go into menu. Why is this so? I backed my files up into my pc and copied everything back. It worked for awhile n the problem came back. I tried the same thing over, my ngage worked when my mmc was empty but as soon as i load everything back in, i cant get into menu. I backed it up again n the ngage wouldnt work even when my mmc is empty. I formatted the mmc using a card reader and it worked again on my ngage but it says my mmc is corrupted.
I've formatted my mmc a few times already. Nothing happens when i connect my ngage to my pc. It only works when i use the card reader. Wad can i do now? Wad was the problem?
Why did this happen??
