I have 6670. I installed the Nokia 6670 Bluetooth modem driver on COM5. Under the modem�s Properties/General it says the device is working properly. PC Suit�s Edit Modem Options also sees it. However, if I do Query Modem under Diagnostics in the modem�s Properties I get an error message: �The modem failed to respond. Make sure it is properly connected and turned on.� Accordingly if I use Nokia One Touch Access it says: �Failed to connect network! One Touch Access couldn�t connect to the selected device.� Can you tell me where the problem is and how to correct it. I can connect 6670 by DKU-2 USB cable and the modem works just fine. Thank you in advance.
