Sendo x: Java File System
2 replies · 1,994 views · Started 22 March 2005
Hello!
What kind of files work with my Sendo X?
I know about the *.SIS Files but most of the Games and Apps I found are *.jad or *.jar...
Is there a trick, I don't know? I normally try to install the applications with the Sendo-Software on my PC. But this does not work with the *.jad or *.jar Files.
Thanks for any help!
Thomas
No tricks, but the .jar files have to contain MIDP 1.0 Java programs (midlets) for the Sendo X. Despite Sun's old claims, Java is not "write once run everywhere"; there are many flavours of Java.
Just transfer the .jar file onto the x with the browse function of sendo pc connect, then go to manage java apps or something (on the x)
