im trying to install nat (network address translation)
Im using the command "netsh routing ip nat install" in command prompt it pauses for a second then a blank link comes up then then the c:\do..... line comes back up
I took it that it worked but then when i try to add an interface it says i have to install nat so i tried it again and got the same thing then i put uninstall instead of install same thing then i put install and still get the same thing
