Wap Push Proxy Gateway ip addresss
0 replies · 4,052 views · Started 23 March 2005
I have a application which uses the http post method over tcp sockets to send a wap push message. Can anyone suggest a suitable WAP PPG which i can use to test the application . I need to know the gateway ip address and the port to which the application should connect.Which port should I connect to ? Is it 4035(wap push).
Comments and suggestions will be appreciated.
