P910i outlook callander time sync problem
3 replies · 7,550 views · Started 23 March 2005
The problem I have experienced with the P910i are the calendar entries I make to/from the PC Outlook to the unit are not being sync properly, I have the wrong time 0f - 2 H.
I have checked all time setting in both GMT etc. and it is the same. Does the unit have a special GMT setting like the PC?
Please advice?
Thanks,
Gil
Gill wrote:Hi,
Please advice?
Thanks,
Gil
Check the timezone of the computer and then refresh outlook datebook timezone settings. I had this problem and corrected it while SE told me to get it for repair.
I think it is a bug in MS outlook. It is not enough to change the timezone of your computer. You must make outlook to see the changes.
I had the same problem...as we in the UK are +1hr due to British Summertime my phone was resetting to GMT. I got round this by turning off the sync with PC time/date option in the 'Properties' menu (right click in PC) on the phone icon in the taskbar.
Uvatha
I have same problem as above. i tried uncheck 'sync cell phone time with pc time' but still not work. i dont know how to make outlook see change in the timezone settings as one of the above guys said. i'm using p910i and Outlook 2003. timezone settings in both p910i and outlook are the same. daylight saving time is set on outlook and summertime is set on p910i. but when i sync, calendar items in p910i are always 1 hour behind.
e.g. if i create item in p910i at 10am, when i sync, it will appear in outlook at 11am. if i create in outlook at 10am, it will appear in p910i at 9am.
please kindly help. any advice is highly appreciated.
