nopEX for A925: Running Apps from memory card - solution!
12 replies · 6,268 views · Started 25 March 2005
Hi2all,
With this very small programm you will be able to install and run applications on external memory card, just like from internal memory.
nopEX and instructions are available here: http://www.nop.at/nopex/
Pls post the name of working and non-working apps, I will collect them and put them on the web-page. Tnx!
And BTW: Vibor v1.3 is available, with single-keypress-switch-global-alert-mode feature: http://www.nop.at/vibor/
the_geek wrote:Pls post the name of working and non-working apps, I will collect them and put them on the web-page. Tnx!
??? Is this any different from starting the applications from any of the (free) filemanagers available (hence 90% of the available applications won't work)?
albatorsk wrote:??? Is this any different from starting the applications from any of the (free) filemanagers available (hence 90% of the available applications won't work)?
Yes, it's different, because you don't have to manually move the application after installation (it can be directly installed to memory card) and it will appear in the system's launcher, and therefor also in any other application-selection, like for the shortcut key etc.
the_geek wrote:Yes, it's different, because you don't have to manually move the application after installation (it can be directly installed to memory card) and it will appear in the system's launcher, and therefor also in any other application-selection, like for the shortcut key etc.
Ok, it's just that I've heard soo many times before "finally, with this solution you will be able to run applications from your memory card", and the never work. I'll give it a whirl and let you know what applications I've tried and which of them works from D:.
Well, with this application, you have without a doubt proven me wrong. It works great!
The apps I've tried that works so far that aren't on your list are Lemmings, n-player and ftp800.
I'm having some trouble with PDF+, though. It won't start when installed on X:. Just pops up an empty requester with a "Continue" button.
BlueEyes doesn't seem to work either. It looks as if it's expecting a file or directory in some place where it can't find it.
hi !
pdf+ is OK on X: ,
blueyes is also OK on X: , but you must put the 2 folders, images + sound on c:
you can also compress your apps on X: with stacker !
but if you have some apps that need to have files on C: , then remember to uncompress them.
/bw
albatorsk wrote:Well, with this application, you have without a doubt proven me wrong. It works great!
I got lemmings, but its on my nes emulator and i cant see it very well - its basically unplayable. was wondering what version of lemmings you got and any links to it perhaps 😃
Ta,
Mitch
I install nopEX program. I run *.sis file to install application but i can't select location. What I'm doing wrong
lp
Alex
mohy2005 wrote:I install nopEX program. I run *.sis file to install application but i can't select location. What I'm doing wrong
lp
Alex
Now is working.
[QUOTE=the_geek]Hi2all,
QuickOffice 3.0 not working
DocumentsToGo don't work.
Get "Missing Component Please Reinstall"
URL to your page?
mohy2005 wrote:[QUOTE=the_geek]Hi2all,
I have installed nopEX and got an error message ("Program Contacts, Reason code: KERN-EXEC, Reason number: 0"😉. Actually, I receive often this kind of error messages... Does anyone has an advice for this? Thank's, Roland
