Does anybody know and have proof about the technical specs. I think the MP3 will be stereo or stereo compatible because nokia wouldnt just include a stereo headset just for the radio. I assume that the pop port has only one set of audio connections. So the MP3 should go through the same as the radio. It may just be the software that makes it mono and crappy, in that case buy and install some good stereo compatible software.
I saw on a web page that the 3230 has the same processor as the 7610. It was on some benchmarking software screenshot. this might of been a test model though.
We need to find the real specs so people dont post arguments about the same things.
samno wrote:Does anybody know and have proof about the technical specs. I think the MP3 will be stereo or stereo compatible because nokia wouldnt just include a stereo headset just for the radio. I assume that the pop port has only one set of audio connections. So the MP3 should go through the same as the radio. It may just be the software that makes it mono and crappy, in that case buy and install some good stereo compatible software.I saw on a web page that the 3230 has the same processor as the 7610. It was on some benchmarking software screenshot. this might of been a test model though.
Read this My Friend.... Nokia is kind enough to include stereo headset just for the radio. They ALSO are DUMB enough to make MP3 Player MONO...
My Apologies...
Ra.
