I installed DTMF dialer 1.01 by Markus Halttunen http://users.tkk.fi/~mhalttu/fun/p800/ on my P800 and now I can not hear any sounds or audio playing from the phone's speaker. I can hear sounds if I plug the sony headset into the phone. If I try to play an audio file and click play then pause and repeat this I can hear a bit of sound from the speaker.
The sony startup sound plays fine and I have had no problems with sound before.
I have tried uninstalling the application, a master reset, formatting
internal memory and a restore using pc suite of the phone (which was
made 1hr before I installed the dialer) but still no sound.
Have tried playing all types of audio files but I can't hear any of them.
Has anyone else had this problem after installing the DTMF dialler?
Does anyone know of a solution?
Thanks.
