Is there any hardware differences between 6670 & 7610?
Find out that their phoneboard is the same.
The only differences is on the keypad board.
Even the rear cover of 7610 fits on 6670
The difference is only in appearance and keypad, and with some bundled/included applications (but apps missing on one you can get separately for the other). Otherwise they are the same.
