Emulator crashes on startup
1 replies · 2,260 views · Started 27 March 2005
i am using the UIQ 2.0 SDK with Windows XP with Codewarrior IDE. After installation of the SDK the Emulator works fine. Now im installing some test/helloworld apps for c++ and suddenly the emulator crashes. It its not possible to start it anymore. It will then crash on startup. Only a reinstallation of the SDK can fix it. But i dont want to install the SDK every 24 hours. 😉 Anybody knows perhaps how to reset the emulator or had this problem too and knwos how to fix it?
Thanx
Christian
