Here's a trick:
When you hold down the menu key, a pop-up window appears showing all running applications. By moving the joystick up/down you can switch to the selected application - something like the Alt-Tab key combination in MS-Windows (I think you knew that already 😉 ).
Now, instead of pressing the "Select" button or pressing the joystick to switch to the selected app, you can press the "C" key, and the selected app will be terminated (like the "End Task" on Win2k).
Have fun! 😉
Alt-Ctrl-Del Tip
simple very simple but a very goooood function. Very necessary. I like it
Thank you
In case you don't have it:
Here's a small app for 7650 that is a complete task manager with hidden stuff (processes, etc). You can download the SIS file or the source code from http://www.ki-ag.de/html/tech/nokiaswitcher.html.
Cheers! 😉
very handy, good find.
its in the quick start manual
just wonderin
yesterday when i played the Ex bubble (fullversion)
when it tries to load it just stop almost at the end of the loading bar
then i switch to the telephone screen or the standby screen and then i hold the menu button to open up the task
and then i select the Ex bubble app and press "c"
guess what my phone just reboot itself i dun kno the reason why
is this bcos there is not enough memory to run or ....
Ex bubble does require a LOT of memory and is very big as well! Puzzle buble is better and smaller and free!
Ah and I forgot to tell you! free up memory space and everything will be fine 😊
hehe 😃
nokiaswitcher is indeed handy to keep 😉 well done sigmacom for contribution this appl to all. Good Work
