how to remove SelecQ from 6600?
2 replies · 3,689 views · Started 28 March 2005
Hello...can anyone tell me how to remove SelecQ from my 6600 devices?because i've been facing difficulty in sending files and photo's using bluetooth function in SeleQ.maybe anyone got any ideas?thanks!!
How apps are usually uninstalled: menu > Tools > Manager > highlight app to uninstall> Options > Remove
A shortcut to replace "Options > Remove": press the 'C' key.
This & other useful pieces of information on how to best use your phone can be found in the phone's User's Guide. If you have lost it, you can download a copy from http://www.nokia.com/phones/6600.
And if that don't work, for some strange reason or another, use a file manager (in this case FExplorer, http://www.gosymbian.com/) to remove program files from its installation directory (in either c:\system\apps or e:\system\apps depending on whether the app was installed in phone memory or the memory card). Be careful not to delete anything you shouldn't.
