Unlike oher series 60 phone 6630 has an Daylight saving option in clock adjustments.
I turned it on, but it didn't changed the time yesterday, anyone know why?
Daylight saving time
i've turned it on, and it forwarded clock by 1h..
Worked for me.
Don't forget that the time went forward at 2am, not midnight 😉
wow didnt even notice that mind done it automatically 😃
no mine didn't go forward automatically, I have an old firmware maybe this is the problem?
Mine went forward eventually after like something stupid like 18hours later.
Ive never seen a Nokia phone ajust correcty for DST at 2am without having to connect to GPRS.
Unplugged wrote:Mine went forward eventually after like something stupid like 18hours later.Ive never seen a Nokia phone ajust correcty for DST at 2am without having to connect to GPRS.
I had mine set to adjust automatically on Sunday but it never, so I adjusted it manually then re-applied the auto time update. Wednesday morning the phone adjusted itself - it went back an hour (making me an hour late for work!!) 😡 so I manually corrected the time again and re-applied the auto time update again. Yesterday all was fine, clock was accurate but this morning my phone readjusted itself back an hour again 😮 !!! I've now switched off the auto time update but can anyone tell me why this happens? I'm using software version 3.45.113
same problem here.. how to setup the phone to work correctly? 🙄
upgrade firmware?? 😎
templ wrote:same problem here.. how to setup the phone to work correctly? 🙄upgrade firmware?? 😎
Does nobody use AUTO TIME UPDATE ??? Help help us out....
My 6630 also has the firmware V 3.45.113 and mine also reverted back to GMT on the auto setting!
Andy
